Автор Тема: 14TV036R0  (Прочитано 217 раз)
14TV036R0
« : 05 Декабря 2023, 12:59:17 »
14TV036R0
Models
RB2T_HX, HJ, HA, HC
Subject: Caution when handling external camera
The external camera is slightly tilted when attached to the unit.
Adjust the L/R tilt with care by using the methods explained below.
IMPORTANT: Push the handle, not the camera itself
Method 1
Method 2 (use this method only when the method 1 is not enough).
NOTE: The shape from the camera may differ depending the model, but the adjustment method remains the same.
