Автор Тема: 14TV031R2  (Прочитано 271 раз)
14TV031R2
« : 05 Декабря 2023, 12:44:24 »
14TV031R2
Models
KD-55X9005A
KD-65X9005A
Subject: Compatibility update with Sony 4K media player (FMP-X5) [REVISION 2]
The unit is not able to play content from the Sony 4K Media Player (FMP-X5).
CAUSE
The “CX mount” from the unit does not support HDCP2.2 contents.
1. Replace the “CX Mount” with below part.
Description Part number
CX2 Mount Service A-1952-947-A
2. Update the unit software to the PKG.3.407 (or later) by referring to 13TV013 for detailed procedure.
3. Update EDID / SPI firmware (see next page for detailed procedure).
Note: After replacing CX board to CX2 board Sound and Picture settings will be switched back to the factory
setting
ASC REPORTING
Repair type Condition code Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
Reactive F 730 14TV031 DPR Y A
2 / 2 13TV031 R2
EDID / SPI firmware update
1. Put the unit in service mode
Press [Display], [5], [Vol+] and [I/O]
2. Press [OPTION] to display the “CHASSIS SERVICE” menu.
3. Press [2] 4 times and [1] twice.
“RUN_EDID_SEQ” is set to “0”.
Press [3] to set the data to “1”.
4. Press [MUTE] and
  • to save the data.
5. Press [1].
“CHECK_SPI_FW” is set to “0”.
6. Press [MUTE] and
  • to save the data.
7. Turn the unit OFF and remove the AC power plug.
8. Wait the unit start up and then turn it OFF/ON again to save the data.
9. Access to service mode again and confirm the “SYF” version as “0047”
APPLICABLE SERIAL NUMBERS
Model Destination Serial number
KD-55X9005A
CEI 6000001~6010000
UKA 6300001~6310000
KD-65X9005A
CEI 6000001~6010000
UKA 6300001~6310000
