Автор Тема: 14TV030R0  (Прочитано 223 раз)
14TV030R0
« : 05 Декабря 2023, 12:43:07 »
14TV030R0
Models
KDL-60W855B
Subject: Stand replacement information
Two different versions of stands are available on the market.
If the stand replacement is needed, please apply below procedure:
1. Identify the version of the stand attached to the unit (refer to below pictures).
2. Replace the stand.
2.1. In case of “Shape A”, order below part.
Side Description Part number
Left Stand L(2L MRS) A 4-539-210-11
Right Stand R(2L MRS) A 4-539-211-11
2.2. In case of “Shape B”, order below part.
Left Stand L(2L MRS) A 4-529-823-11
Right Stand R(2L MRS) A 4-529-824-11
IMPORTANT: If the needed “Shape B” stand (left or right) is no longer available, you must replace both stands
by the “Shape A” version. “Shape A” and “Shape B” stands must never be mixed on the same unit.
