Автор Тема: 14TV021R0  (Прочитано 222 раз)
14TV021R0
« : 05 Декабря 2023, 12:38:12 »
14TV021R0
Models
ITC3-ME chassis
Subject: No picture via HDMI input
No picture issue may happen when a non-standard HDMI cable is used.
CAUSE
Contacts lengths from non standard HDMI cable are shorter than on standard one.
If the customer points out the above symptom, please follow below steps.
1. Connect a standard HDMI cable (with HDMI logo) and check the picture.
 If the picture is properly displayed, jump to next step.
 If the picture is not displayed, the issue is out of scope of this Technical Bulletin and further
investigations are needed.
2. Replace the “Bracket Side” with the improved part.
Description Part number
Bracket, Side (SCL) 4-476-232-02
Condition
Code
Symptom
code
Part
Number
Ref.
Section
Code
PCB
Defect
Code
Repair
Code
Qty.
F 310 4-476-232-02 14TV021 EXC A1 A 1
