Автор Тема: 14TV020R0  (Прочитано 206 раз)
14TV020R0
« : 05 Декабря 2023, 12:36:28 »
14TV020R0
Models
RB2-G_HE-H, HT Chassis
KD-55X9005A
KD-65X9005A
Subject: Stand Slanting adjustment
The stand is not attached perpendicularly with the screen.
CAUSE
 The stand has not been installed properly as described in the “Quick Setup Guide” and “Supplement”.
 The unit has not been handled accordingly the “Quick Setup Guide” (e.g. single person handling).
1. Confirm the presence of the below 4 screws (2x left / 2x right).
2. Loosen the 4 screws (3x counter clockwise rotation) without removing them from the screw holes.
2 / 2 14TV020
3. Perform the adjustment for the slanted stands as shown below.
IMPORTANT: Two persons are required to perform the adjustment. The first which lifts the TV, while the second one adjusts the stand position.
4. Confirm that the stands are now perpendicular with the panel.
5. Tight the screws again while adjusting the TV to the correct position.
