Автор Тема: 14TV018R0  (Прочитано 271 раз)
14TV018R0
« : 05 Декабря 2023, 12:35:06 »
14TV018R0
Models
RB2G-HE-L(3D) chassis
KDL-42W705B, 706B
Subject: No power with “ACDP-120E02” AC adaptor
The unit does not turn ON and the Standby LED is not lighted.
CAUSE
The “ACDP-120E02” AC adaptor may be defective.
In case of above symptom please follow below steps:
1. Check if the “ACDP-120E02” AC adaptor is within below range
Model Part number Suspicious S/N range
ACDP-120E02 1-492-731-11, 12, 13, 14 13108000001~14038105504
2. Confirm that the “ACDP-120E02” AC adaptor is defective and replace it with below part.
Description Part number S/N
ACDP-120N02
1-492-733-11 All
1-492-731-14 From 14038105505
NOTE: If the “ACDP-120E02” AC adaptor is not defective, further investigations are needed.
