Автор Тема: 14TV015R0  (Прочитано 235 раз)
14TV015R0
« : 05 Декабря 2023, 12:32:37 »
14TV015R0
Models
RB1-FK_BA
Subject: Constantly or intermittently no power
The unit will constantly or intermittently not turn ON.
NOTE: All voltages from PSU are OK.
CAUSE
The Power button from the “Switch Unit” is not aligned correctly with the board.
If you disconnect the harness from the “Switch Unit”, the set will power up normally with the Remote commander.
Please replace the “Switch Unit” with below part.
Description Part number
Switch Unit 1-492-329-21
