Автор Тема: 14TV006R0  (Прочитано 271 раз)
14TV006R0
« : 05 Декабря 2023, 10:59:17 »
14TV006R0
Models
KD-55X9005A
KD-65X9005A
Subject: T-Con Board Replacement
The T-con board for the listed models has been registered for service.
In case of any of T-con board failures like explained in TV000031, do not exchange the entire panel, but simply
replace the T-con board according to the part number info below.
- When the T-Con board is replaced please apply actions like described from p.15 onwards in the “Service
Procedure for Panel, Board and Software Change / Upgrade (RB1FS)” available in ASSIST under Doc Ref
98881430x.
- Use new AL-Tape for EMC according to the part number info below.
Description Part number
MOUNTED PWB E-T-CON(55) 1-895-397-11
MOUNTED PWB E-T-CON(65) 1-895-396-11
AL Sheet FFC (55) 4-455-609-01
AL Sheet FFC (M CCT) (65) NOT stocked, re-use
