Автор Тема: 14TV002R0  (Прочитано 225 раз)
14TV002R0
« : 05 Декабря 2023, 10:55:26 »
14TV002R0
REACTIVE 2 SBR
Models
RB1G_HG, LW_WXGA, LW, MH, MW Chassis
RB1-FK_BA Chassis
RB1-FS_FB, FSL, FSM Chassis
RB1-CM_CM Chassis
Subject: Cannot log into Skype after firmware update
After having updated the unit firmware to PKG4.101, it may no more be possible to log into Skype.
CAUSE
When the unit is updated to PKG4.101, access error may occur when trying to log into Skype.
If the above symptom occurs, please perform a factory reset from the unit by following below steps:
 Press [Home] and select [Settings] > [System Settings] > [General Set-Up] > [Factory Settings] > [Yes].
NOTE: “Factory Reset” resets all user data and settings including TV channels, network set-up, login information
