Автор Тема: 14TV001R0  (Прочитано 240 раз)
14TV001R0
« : 05 Декабря 2023, 10:54:03 »
14TV001R0
REACTIVE SBR
Models
RB1G_HG, MW Chassis
Subject: A screw fixing the stand cannot be removed
One (or more) of the screws fixing the stand to the unit cannot be removed.
CAUSE
Because of the use of screws with glue, the required unscrewing torque may be too high.
If the customer points out the above symptom, please try below steps:
Try to remove the blocked screw with pliers or drill.
IMPORTANT: Do not use chemicals and take care not to damage the screw thread on the panel.
 When the blocked screw is removed, clean up the screw thread on the panel by screwing/unscrewing
below part at least 5 times.
Description Part number Picture
SCREW,+PSW M5X16 LOCK(SERVI 4-467-935-01
NOTE: If the “Stand Head” has been damaged, please replace it by a new one.
STAND HEAD NECK (L) 4 - 4 49-241-13
