Автор Тема: 13TV036R1  (Прочитано 285 раз)
13TV036R1
« : 05 Декабря 2023, 08:20:21 »
13TV036R1
REACTIVE 2 SBR
Models
KD-84X9005
Subject: Compatibility update with Sony 4K media player (FMP-X5) [REVISION 1]
For HDMI 2.0, replace “CV3” by “CV4” board.
The unit does not detect the new “CV4” board.
 In case of “CV3” by “CV4” board replacement
1. Update the unit software by USB (PKG1505 or later)
Refer to “Software update procedure” in this document or to 13TV003 Technical Bulletin.
2. Order and replace the “CV4” board
Description Part number
CV4 Comple Service A-1998-817-A
3. Go into the service mode and change the “CV4_DET” item
Refer to “CV4_DET item change” in this document.
 In case of defective “BAPS” board
1. Check the CV board version which is installed in the unit
2. Order and replace the “BAPS” board
BAPS-T2C2S2 Comple Service A-1905-681-A
ASC REPORTING
Repair type
Condition
code
Symptom
code
Part
number
Ref.
Section
code
PCB
Defect
code
Repair
code
Qty.
Upgrade F 716 A-1998-817-A 13TV036 VPD CV3 Y 3 1
Reactive A-1905-681-A 13TV036 BAPS N A 1
CV3 board
CV4 board
2 / 3 13TV036 R1
3. Update the unit software by USB (PKG1505 or later) Refer to “Software update procedure” in this document or to 13TV003 Technical Bulletin..
4. If the unit is equipped with the “CV3” board the procedure is complete. If the unit is equipped with the “CV4” board jump to next step.
5. Go into the service mode and change the “CV4_DET” item if needed. Refer to “CV4_DET item change” in this document.
1. Prepare the USB memory (including USB image and unzip file).
2. Turn the unit ON.
3. Insert the USB memory into the main board USB slot.
4. The unit starts the software update.
5. After around 5 minutes the unit will reboot by itself and the complete message will be displayed.
6. Remove the USB memory and select [OK].
CV4_DET item change
1. Go into the service mode: In standby, press [i+] > [5] > [Vol+] > [I/O].
2. Press [OPTION] “Chassis Service” menu appears.
3. Press [2] 4 times and [1] 4 times “CV4_DET” is displayed.
13TV036 R1 3 / 3
4. Press [3] to change the data.  CV3 board to “0”  CV4 board to “1”
5. Press [MUTE] and
  • to save the data.
6. Unplug/plug the AC power.
7. Turn the unit ON and wait 30 seconds or more.
8. Go into the service mode and confirm that “CV4_DET” value is set correctly.
9. Exit the service mode and check Picture/Sound from HDMI-2 input.
