Автор Тема: 13TV033R0  (Прочитано 243 раз)
13TV033R0
« : 05 Декабря 2023, 08:17:50 »
13TV033R0
Models
RB1G_HG, LW_WXGA, LW, MW Chassis
KD-55X9005A
KD-65X9005A
Subject: Unit boots by itself
The unit boots by itself when connected to a wireless router.
CAUSE
When the router is set in “Eco / Standby” mode, it will send a “deauthentication” packet. When the TV receives this
packet, it will switch ON by itself (Wake up on WLAN).
Update the unit to the latest software (PKG 3710 or later).
NOTE: This issue can be temporally solved by changing the Wi-Fi settings from the router or the unit.
 Router: Turn the “Eco / Standby” mode OFF.
 Unit: Press [HOME] and select [SETTINGS] > [HOME NETWORK SETUP] > [REMOTE START] > [OFF].
