Автор Тема: 13TV031R1  (Прочитано 294 раз)
13TV031R1
« : 05 Декабря 2023, 08:15:18 »
13TV031R1
Models
RB1G_HG Chassis
Subject: “Flexible Flat Cable 32P” and “Panel Assy” compatibility [REVISION 1]
Due to “LD Board" size change, the compatibility between the panel and the flexible cable must be considered.
If Flexible Flat Cable needs to be replaced, please refer to below table to check the compatibility.
APPLICABLE SERIAL NUMBERS
Model Destination Serial number Old design Serial number New design
KDL-40W905A
CEI 6000001~ 6007638 6007639~
UKA 6300001~ 6301296 6301297~
CEL 7200001~ 7201020 7201021~
KDL-46W905A
CEI 6000001~ 6025084 6025085~
UKA 6300001~ 6304442 6304443~
CEL 7200001~ 7202992 7202993~
KDL-55W905A
CEI 6000001~ 6022068 6022069~
UKA 6300001~ 6304500 6304501~
CEL 7200001~ 7202284 7202285~
