Автор Тема: 13TV030R2  (Прочитано 288 раз)
13TV030R2
« : 05 Декабря 2023, 08:13:59 »
13TV030R2
REACTIVE 2 SBR
Models
RB1G_LW, LW_WXGA Chassis
Subject: Introduction of “BLE/BLT” boards [REVISION 2]
Two versions of main board and tuner board have been used during production.
 BKE/BKT boards (AYU2).
 BLE/BLT boards (AYU2L)
If the main or tuner board replacement is needed, please order as long as available, the part which corresponds to
the unit (refer to the table at the end of this Technical Bulletin).
IMPORTANT: In case of BKE or BKT boards are no longer available and a combination of BLE and BLT boards is
needed, some EMC countermeasure and mechanical modifications have to be done. The correct power adaptor
must also be used. Please follow below procedure.
1. EMC Countermeasure
1.1. Order below parts.
Description Part number Qty
Flexible Flat Cable 51p
1-846-622-21
or
1-846-623-21
1
Sheet Core C 4-000-896-01 1
Tape, Shield (30x100) 4-465-731-01 2
Gasket 20*30 4-118-052-01 1
1.2. Apply the EMC countermeasure as indicated below.
ASC REPORTING
Repair type
Condition
code
Symptom
code
Part
number
Ref.
Section
code
PCB
Defect
code
Repair
code
Qty.
Reactive 13TV030 N A
1-846-622-21
or
1-846-623-21
Sheet Core C
4-000-896-01
4-465-731-01
4-465-731-01
Gasket 20*30
4-118-052-01
On chassis box assy (tuner FFC) On panel assy
2 / 3 13TV030 R2
2. Mechanical modifications.
2.1. Order the additional mechanical parts.
Description
Part number
Label, Side Terminal R (MMB)
4-458-886-41
Bracket, Side Tuner (MMB)
4-439-637-33
2.2. Replace the unit terminal bracket and label with the new parts as indicated below.
NOTE:
 BKE/BKT (AYU2 processor): With Heat sink.
 BLE/BLT (AYU2L processor): Without Heat sink.
3. Power adaptor.
3.1. Refer to below tab to be sure to use the correct power adaptor.
Panel size
Description
Part number
32’
AC Adaptor (85W)
1-492-294-11
42’
AC Adaptor (120W)
1-492-293-11
or 1-492-295-11
BKE/BKT (AYU2)
BLE/BLT (AYU2L)
Bracket, Side Tuner (MMB) 4-439-637-33 + Label, Side Terminal R (MMB) 4-458-886-41
Sony Europe Limited
Customer Satisfaction Europe
Quality & Service Engineering
3 / 3
APPLICABLE SERIAL NUMBERS
Model
Product code
Destination
Board Serial number
S/N
BKE
BKT
S/N
BLE
BLT
KDL-32W600A
185372x0
CEI
6000001~6100000
A-1927-454-A
A-1940-820-A
6100001~6300000
A-1959-085-A
A-1955-080-A
KDL-32W603A
185510x0
6000001~6100000
A-1927-456-A
A-1940-821-A
6100001~6300000
A-1959-085-A
A-1955-080-A
KDL-32W605A
185514x0
6000001~6100000
A-1927-458-A
A-1940-822-A
6100001~6300000
A-1959-085-A
A-1955-080-A
KDL-32W650A
185205x0
6000001~6100000
A-1927-454-A
A-1940-820-A
6100001~6300000
A-1959-085-A
A-1955-080-A
KDL-32W651A
185782x0
6000001~6100000
A-1927-454-A
A-1940-820-A
6100001~6300000
A-1959-085-A
A-1955-080-A
KDL-32W653A
185509x0
6000001~6100000
A-1927-456-A
A-1940-821-A
6100001~6200000
A-1959-085-A
A-1955-080-A
KDL-32W654A
185783x0
6200001~6250000
A-1927-456-A
A-1940-821-A
6250001~6300000
A-1959-085-A
A-1955-080-A
KDL-32W655A
185513x0
6000001~6100000
A-1927-458-A
A-1940-822-A
6100001~6300000
A-1959-085-A
A-1955-080-A
KDL-32W656A
185786x0
6000001~6100000
A-1927-458-A
A-1940-822-A
6100001~6300000
A-1959-085-A
A-1955-080-A
KDL-42W650A
185204x0
6000001~6100000
A-1923-824-A
A-1940-820-A
6100001~6300000
A-1955-079-A
A-1955-080-A
KDL-42W651A
185787x0
6000001~6100000
A-1923-824-A
A-1940-820-A
6100001~6300000
A-1955-079-A
A-1955-080-A
KDL-42W653A
185508x0
6000001~6100000
A-1923-825-A
A-1940-821-A
6100001~6200000
A-1955-079-A
A-1955-080-A
KDL-42W654A
185791x0
6200001~6250000
A-1923-825-A
A-1940-821-A
6250001~6300000
A-1955-079-A
A-1955-080-A
KDL-42W655A
185512x0
6000001~6100000
A-1923-826-A
A-1940-822-A
6100001~6300000
A-1955-079-A
A-1955-080-A
KDL-42W656A
185788x0
6000001~6100000
A-1923-826-A
A-1940-822-A
6100001~6300000
A-1955-079-A
A-1955-080-A
KDL-32W603A
185527x4
CEL
7200001~7300000
A-1927-456-A
A-1940-821-A
7300001~7500000
A-2031-474-A
A-1955-080-A
KDL-32W653A
185526x4
7200001~7300000
A-1927-456-A
A-1940-821-A
7300001~7500000
A-2031-474-A
A-1955-080-A
KDL-32W654A
185785x0
7200001~7300000
A-1927-456-A
A-1940-821-A
7300001~7500000
A-2031-474-A
A-1955-080-A
KDL-42W653A
185525x4
7200001~7300000
A-1923-825-A
A-1940-821-A
7300001~7500000
A-2031-475-A
A-1955-080-A
KDL-42W654A
185790x0
7200001~7300000
A-1923-825-A
A-1940-821-A
7300001~7500000
A-2031-475-A
A-1955-080-A
KDL-32W603A
185695x3
RU3
1800001~1804988
A-1927-456-A
A-1940-821-A
1804989~1805038
A-1959-085-A
A-1955-080-A
1805039~1805538
1805539~1805638
1805639~1900000
1900001~2000000
KDL-32W653A
185696x3
1800001~1806999
A-1927-456-A
A-1940-821-A
1807000~1807049
A-1959-085-A
A-1955-080-A
1807050~1807663
1807664~1807763
1807764~1900000
1900001~2000000
KDL-42W653A
185697x3
1800001~1807477
A-1923-825-A
A-1940-821-A
1807478~1807527
A-1955-079-A
A-1955-080-A
1807528~1809252
1809253~1809352
1809353~1900000
1900001~2000000
KDL-32W603A
185510x1
UKA
6300001-6400000
A-1927-456-A
A-1940-821-A
6400001-6600000
A-1959-085-A
A-1955-080-A
KDL-32W653A
185509x1
6300001~6400000
A-1927-456-A
A-1940-821-A
6400001~6500000
A-1959-085-A
A-1955-080-A
KDL-32W654A
185783x1
6500001~6550000
A-1927-456-A
A-1940-821-A
6550001~6600000
A-1959-085-A
A-1955-080-A
KDL-42W653A
185508x1
6300001~6400000
A-1923-825-A
A-1940-821-A
6400001~6500000
A-1955-079-A
A-1955-080-A
KDL-42W654A
185791x1
6500001~6550000
A-1923-825-A
A-1940-821-A
6550001~6600000
A-1955-079-A
A-1955-080-A
