Автор Тема: 13TV027R1  (Прочитано 241 раз)
13TV027R1
« : 05 Декабря 2023, 08:10:17 »
13TV027R1
REACTIVE 2 SBR
Models
KDL-32R420A, 421A, 423A, 424A
Subject: Compatibility between GL3B and GL3C Static Converter [REVISION1]
The “GL3B” static converter has been replaced by “GL3C”.
CAUSE
The EMC performance has been improved.
Refer to the table at the end of this Technical Bulletin for corresponding parts.
IMPORTANT: In case of change from “GL3B” to “GL3C”, change also the “Connector Assy” (1-910-107-98) and
delete the “Ground Cable”. The Power Supply cords are compatible.
Differences between GL3B and GL3C configuration
GL3B
1-474-519-11
GL3C
1-474-519-21
Ground Cable
1-910-108-01
Connector Assy
1-910-107-98
(with ferrite core)
Connector Assy
1-910-108-91
(without ferrite core)
No Ground Cable
2 / 2 13TV027 R1
Parts list
GL3 version
Description
Part number GL3B GL3B(ID)-Static Converter(TV) 1-474-519-11 Power-Supply Cord UK 1-846-663-31 Power-Supply Cord EU 1-846-662-31 Connector Assy 32 MB-SP LR 4P 1-910-107-98 Ground Cable 32 MB-Source 1-910-108-01 GL3C GL3C(ID)-Static Converter(TV) 1-474-519-21 Power-Supply Cord UK 1-846-663-71 Power-Supply Cord EU 1-846-662-71 Connector Assy 32 MB-SP LR 4P 1-910-108-91
APPLICABLE SERIAL NUMBERS
Model
Product
code
PSU Serial number
GL3B
GL3C
32R420A
18520730
6000001~6025606
6025607~6030706
6030707~6030907
6030908~6150000
18520750
6150001~6164666
6164667~6165023
6165024~6166713
6166714~6250000
32R421A
18555730
6000001~6006997
6006998~6100000
18555750
6150001~6151469
6151470~6151623
6151624~6151777
6151778~6200000
32R423A
18550301
6300001~6306745
6306746~6307050
6307051~6307520
6307521~6600000
18550340
6100001~6102759
6102760~6103861
6103862~6104369
6104370~6150000
18550350
6150001~6157445
6157446~6158911
6158912~6159696
6159697~6200000
18550360
6200001~6205369
6205370~6205738
6205739~6205846
6205847~6250000
32R424A
18555940
6100002~6100241
6100242~6100386
6100387~6150000
18555950
6150000~6150594
6150595~6200000
18555960
6200001~6204887
6204888~6250000
