Автор Тема: 13TV026R0  (Прочитано 207 раз)
13TV026R0
« : 05 Декабря 2023, 08:09:01 »
13TV026R0
REACTIVE
2
SBR
Models
KD-55X9005A KD-65X9005A
Subject: “Mounted PWB (Network)” board compatibility
Two, non compatible, versions of “Mounted PWB (Network)” are available in the sets:
 “Mounted PWB (Network)”  1-895-387-12
 “Mounted PWB (Network)”  1-895-387-31
NOTE: Only the suffix 12 version is available as service part.
In case of failure of “Mounted PWB (Network)” you need to replace both boards (left & right).
Description
Part number
1-895-387-12
IMPORTANT: Take care to never mix suffix 12 and suffix 31 versions in the same unit.
