Автор Тема: 13TV024R2  (Прочитано 224 раз)
13TV024R2
« : 05 Декабря 2023, 08:06:40 »
13TV024R2
REACTIVE 1385 2 TD
Models
All 2010-2015 TV Models
Subject: Panel Specs for Pixel Problem [REVISION 2]
INSPECTION CONDITION
Ambient condition
* Temperature: 25 ± 5 °C
* Illumination: 100~150 lux
Viewing distance
* 100~120 cm from the LCD module
 If the defect is only visible from within this distance, then do not consider it as a problem.
Viewing angle
* 90 degrees (± 45° left / right) between the module surface and the inspector’s line of view
LCD AREA DEFINITION
The LCD is divided in two areas as shown below.
