Автор Тема: 13TV023R0  (Прочитано 224 раз)
13TV023R0
« : 05 Декабря 2023, 08:04:58 »
13TV023R0
REACTIVE
2
SBR
Models
KD-55X9005A KD-65X9005A
Subject: Caution when replacing “CX Mount”
The unit software needs to be updated after the “CX Mount” replacement.
CAUSE
The replacement “CX Mount” does not have the proper HDMI EDID data.
1. Replace the “CX Mount” with below part.
Description
Part number
CX Mount
A-1936-361-A
2. Update the unit software to the latest version (refer to 13TV013 for detailed procedure).
3. Update EDID / SPI firmware (see next page for detailed procedure).
2 / 2 13TV023
EDID / SPI firmware update
1. Put the unit in service mode Press [i+], [5], [Vol+] and [I/O]
2. Press [OPTION] to display the “CHASSIS SERVICE” menu.
3. Press [2] 4 times and [1] twice. “RUN_EDID_SEQ” is set to “0”. Press [3] to set the data to “1”.
4. Press [MUTE] and
  • to save the data.
5. Press [1]. “CHECK_SPI_FW” is set to “0”. Press [3] to set the data to “1”.
6. Press [MUTE] and
  • to save the data.
7. Turn the unit OFF and remove the AC power plug.
APPLICABLE SERIAL NUMBERS
Model
Destination
Serial number
KD-55X9005A
CEI
6000001~6010000
UKA
6300001~6310000
CEL
7200001~7210000
KD-65X9005A
CEI
6000001~6010000
UKA
6300001~6310000
CEL
7200001~7210000
