Автор Тема: 13TV019R0  (Прочитано 206 раз)
13TV019R0
« : 05 Декабря 2023, 08:00:46 »
13TV019R0
REACTIVE 2 SBR
Models
RB1G_LW, LW_WXGA (32/42) Chassis
Subject: Unit may drop when fixed on wall
The unit may drop when installed with the wall-mount and pulled strongly.
CAUSE
The screw studs are snatched when the unit is strongly pulled when attached to the wall.
Follow below flowchart and apply the recommended countermeasures.
Panel week code:
13/27 or earlier?
Wall mounts studs
loose and movable by
finger?
Used on wall mount
condition?
C/M applied panel
available?
Customer TV unit
Trigger AEP to C/M one Trigger AEP
Add countermeasure accessory bag
End
YES
YES
YES or Unknown
YES
NO
NO
NO
NO
Refer to :
“How to check the panel week code”
Refer to :
“How to check the wall mount studs”
Refer to :
“C/M applied panels”
Refer to:
“Countermeasure bag”
2 / 2 13TV019
The studs shape has been improved in production since July 1st 2013.Refer to below picture to check if the countermeasure has been applied on the panel.
C/M applied panels
Panel reference
Bezel color
Old part number
New part number
T320XVF05.0
Black
1-811-797-12
1-811-797-13
T320HVF01.0
Black
1-811-798-11
1-811-798-12
T320HVF01.1
Silver
1-811-798-21
1-811-798-22
T420HVF04.1
Silver
1-811-799-11
1-811-799-12
T420HVF04.0
Black
1-811-799-21
1-811-799-22
Countermeasure accessory bag
1. Order the countermeasure accessory bag
Description
Part number
WM RING (WMB) A
4-480-240-01
2. Download the instruction sheet attached to this technical bulletin.
Date
August 2013
13TV019_leaflet.pdf
