Автор Тема: 13TV012R0  (Прочитано 201 раз)
13TV012R0
« : 05 Декабря 2023, 07:54:00 »
13TV012R0
REACTIVE 2 SBR
Models
KDL-46EX720, 721, 723, 724, 725, 726, 727, 728, 729
KDL-46NX720, 723, 725
KDL-46HX820, 823, 825
Subject: No power ON / LED blinking 2 times
The set may not power on at all (no picture and 2 times LED blinking) or LED error 2 may occur intermittently.
CAUSE
Defective resistors on power supply board.
1. Check Error Log for “Error 2 count >0”.
2. Check the PSU board serial number. The serial number should be within below range.
Description Label info Serial number
Static Converter (TV)-G5AW 1-474-307-11 1108Ab014884 or before
Static Converter (TV)-G5D 1-474-309-11 1109Ab200001 or before
3. Replace the 4 resistors (R6541, R6542, 6537 and R6538) by the one indicated below.
Description Part number
Fixed Chip Resistor 2M (3216) – 0.5%
or
Res, Metal Film 2M (3216) – 1%
1-248-249-11
or
1-257-085-11
ASC REPORTING
Condition
code
Symptom
code
Part
number
Ref.
Section
code
PWB
Defect
code
Repair
code
Qty.
2 11D
13TV012 PSU N A
2 / 2 13TV012
4. Let the set age for 30 minutes.
5. Reset the Error Log.
IMPORTANT
 After replacing the defective component, make sure to add a check mark next to the module label.
 Component level repair must only be conducted if the workshop can perform a Hi-pot or insulation test.
 If the power board is not fixed even after changing the resistors, do not attempt any other parts replacement. Just replace the entire PSU board. Description Models Part number G5AW-Static Converter (TV) KDL-46NX72x, HX82x FX0028511 G5D-Static Converter (TV) KDL-46EX72x FX0009411
