Автор Тема: 13TV022R3  (Прочитано 429 раз)
13TV022R3
« : 04 Декабря 2023, 18:22:35 »
13TV022R3
Models
RB1FK_BA Chassis
Subject: Software packages follow-up for RB1FK chassis [REVISION 3]
The latest software packages have been released, remedying the issues below.
Issues IRIS
code
Section
code Segment Rev.
Wrong time displayed on banner in DVB-T (Finland) 6171 IDS
Sound settings cannot be reset via “Sound Reset” option C57X SWO ALL R0
Commands interrupted while connected via MHL K270 REM
No sound and sometimes pink picture with analogue input or TV
reception C510 APD
ALL R1
Wrong time displayed in summer time with “Tele2” (Sweden) U171 IDS
EPG stops after few seconds (Norway) 3286 SYS
ALL R2
No playback of USB Video/Photo files when a DVB-T2 CAM is
inserted in the TV CAM slot F781 SYS
TV blocks after changing channel and immediate use of
EPG/Guide 628C SYS
Boxer TV channels cannot be descrambled using Neotion CAM
(Denmark) D210 VPD
Subtitles disappear after launching EPG on BBC2HD service
(UK) C286 SYS
Pop noise when connected to external device C544 APD
Update with the latest software package, following the abridged procedure below.
IMPORTANT: During the firmware installation process, do not remove the USB device, switch off the TV set or
remove the power.
NOTE: For full software procedure please check Service Manual 9-888-532-xx.
1. Download and unzip the applicable file attached to this Technical Bulletin and copy the extracted folder to
the root of an empty USB stick.
Date Attachment SW version
May 2014 RB1FK_v4010_AEF.zip 4.010
ASC REPORTING
Repair type Condition
code
Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
Proactive (NPF) 13TV022 SFT 6 2
Reactive (issue not listed) 13TV022 1 2
Reactive (issue listed) issue issue 13TV022 issue 1 3
2 / 2 13TV022 R3
Sony Europe Limited
Service, Quality and Environment
Service Engineering
2 / 2
2. Turn the TV ON.
3. Insert the USB stick into the USB slot located at the side of the TV set.
4. Go to USB System Update.
Press [HOME], and select “Settings” > “Set-up” > “USB System Update”
5. When the LED lights up in green, the firmware update is finished.
6. Check if the firmware version is the latest one.
13TV022 - Software packages follow-up for RB1FK chassis [REVISION 3]
DTV027000097009_00000100
