Автор Тема: 13TV013R25  (Прочитано 563 раз)
13TV013R25
« : 04 Декабря 2023, 17:51:18 »
13TV013R25
Models
RB1G_HG, LW, LW_WXGA, MH, MW, L2 Chassis
RB1FS_FB, FSL, FSM Chassis
RB1CM
Subject: Software packages follow-up for RB1G chassis [REVISION 25]
NOTE: For full software procedure please check Service Manual 9-888-142-0x (“Service Procedure for Panel and
Software Change / Upgrade”).
1. Download and unzip the applicable file attached to this Technical Bulletin and copy the extracted folder
(including a BIN file) to the root of an empty USB stick.
Date Attachment SW version
November 2015
RB1G_v4560_EUA.zip 4.560
RB1G_v4560_EUB.zip For Italy 4.560
2. After AC plug-in, wait for 20s then turn the unit ON via [POWER] button on remote.
IMPORTANT: It is necessary to wait 20s for successful FW writing.
3. Insert the USB stick into the USB slot located at the side of the TV set.
4. A series of different messages will appear on the TV set. Please follow the on-screen instructions.
5. First, the TV will copy update file from USB, then the POWER indicator will start flashing under updating
process (White color).
6. After minutes, the TV will reboot to complete the update.
7. When the firmware update is complete, a message is displayed on the TV.
It is now safe to remove your USB device from the USB slot.
13TV013 - Software packages follow-up for RB1G chassis [REVISION 25]
DTV0FA30A05A0A5_00002100
DTV0FA30A05A0A5_00012100
