Автор Тема: 13TV003R5  (Прочитано 356 раз)
13TV003R5
« : 04 Декабря 2023, 17:45:10 »
13TV003R5
Models
KD-84X9005
Subject: Software packages follow-up for AZ-3SR_FS-H chassis [REVISION 5]
One of the following symptoms may occur.
Issue IRIS code Section code Rev.
Skylink services unavailable in Slovakia
*TV displays ”CA module is not authorized for this service” error
message.
K719 DPR R0
Wrong supported channels displayed on ARD “HbbTV” portal
*After 1mn, TV loads correct “HbbTV” content. D720 DPR
Numerical keys not working on La7 (Italia) R1
*Numerical keys are not working on La7 after MHP banner has been
loaded.
E152 NIF
Crash and freeze when using “HbbTV” function C11F DPR
Internet connectivity problems D78X DPR R2
Satellite services disappear after Satellite database modification in
PC. S21A VPD
R3
TV reboots sporadically while navigating in EPG Guide. 211F SYS
HDMI 2.0 Upgrade. F330 VPD R4
Login issue with PMO / Twitter / Facebook / Weibo / 500px. SSL 3.0
protocol vulnerability. C73X SWA R5
Update with the latest software package, following the below procedure.
1. Download and unzip the file attached to this Technical Bulletin and copy the extracted folder (including a BIN
file) to the root of an empty USB stick.
Date Attachment SW version
December 2014 AZ-3FSH_v1510.zip Pkg 1.510 EUG
ASC REPORTING
Repair type Condition
code
Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
Proactive (NPF) 13TV003 SFT 6 2
Reactive (issue not listed) 13TV003 1 2
Reactive (issue listed) issue issue 13TV003 issue 1 3
2 / 2 13TV003 R5
2. Turn on the TV and insert the USB stick.
 The green and amber LEDs will start blinking for a while.
 The set will reset after about 1 minute.
 The Standby LED will light and the Communication LED blinks.
 The set will automatically reboot and a message will be displayed indicating that the upgrade is
finished.
3. Remove the USB stick and press the [Enter] button on remote commander while the set is turned on.
13TV003 - Software packages follow-up for AZ-3SR_FS-H chassis [REVISION 5]
DTV0FA20A03A0A3_00071100
