Автор Тема: 12TV041R0  (Прочитано 205 раз)
12TV041R0
« : 04 Декабря 2023, 17:37:04 »
12TV041R0
KDL-32EX700, 701, 703, 705, 706, 707, 708, 709
KDL-40EX700, 701, 703, 705, 706, 707, 708, 709, 710, 711, 713, 715, 716, 717, 718, 719
KDL-40LX900, 903, 904, 905
KDL-40NX700, 703, 705, 800, 803, 805
KDL-46EX700, 701, 703, 705, 706, 707, 708, 709, 710, 711, 713, 715, 716, 717, 718, 719
KDL-46NX700, 703, 705
KDL-52EX700, 703, 705
KDL-52LX900, 904, 905
KDL-52NX800, 803, 805
KDL-55EX710, 713, 715
KDL-60LX900, 903, 905
Subject: Caution when replacing LCD Panel or T-CON
Power Supply cycling (repeated ON/OFF) may happen after replacing the LCD Panel or T-CON board.
CAUSE
Short circuit on T-CON board.
Change fuse “PS6150/6151” in the 12V circuit on the Power Supply Board.
 When ordering a new fuse, please use the part number below.
Description Part number
Link, IC (7A) 1-533-790-42
 Below cross reference table shows the fuse reference number mentioned on the PSU board.
Model PSU board Fuse PS6150 Fuse PS6151
KDL-46/52EX70x, 46/55EX71x, 46NX70x, 52NX80x GE2B (1-474-212-1x) x
KDL-32/40EX70x, 40/46EX71x, 40NX70x, 40NX80x GE3A (1-474-213-1x) x
KDL-40LX90x GE5 (1-474-222-1x) x
KDL-52LX90x GE4B (1-474-221-1x) x
KDL-60LX90x GE4A (1-474-220-1x) x
CAUTION
 After replacing the defective component, make sure to add a check mark next to the module label.
 Component level repair must only be conducted if the workshop can perform a Hi-pot or insulation test.
 If the power board is not fixed even after changing the fuse, do not attempt any other parts replacement. Just
replace the entire PSU board.
 If the board shows burn marks or physical damage, do not attempt to repair.
