Автор Тема: 12TV040R0  (Прочитано 212 раз)
12TV040R0
« : 04 Декабря 2023, 17:33:20 »
12TV040R0
Models
KDL-40EX650, 653
KDL-46EX650, 653
Subject: No power ON / LED blinking 6 times
The set may not power on at all (no picture and 6 times LED blinking) or LED error 6 may occur intermittently.
CAUSE
LED OVP circuit malfunction due to LED OVP detection resistor value failure.
1. Check Error Log for “Error 6 count >0”.
2. Check the PSU board serial number. The serial number should be within below range.
Serial number
1202E003277~1205E035630
1203E330073~1205E313784
3. Replace both resistors by the one indicated below.
Description Part number
220K 1/10W Chip Resistor 9-913-802-16
4. Let the set age for 30 minutes.
5. Reset the Error Log.
ASC REPORTING
Condition
code
Symptom
code
Part
number
Ref.
Section
code
PWB
Defect
code
Repair
code
Qty.
2 11D 9-913-802-16
R6805
R6807
PSU N A 1
2 / 2 12TV040
CAUTION
• After replacing the defective component, make sure to add a check mark next to the module label.
• Component level repair must only be conducted if the workshop can perform a Hi-pot or insulation test.
• If the power board is not fixed even after changing the fuse, do not attempt any other parts replacement. Just
replace the entire PSU board.
• If the board shows burn marks or physical damage, do not attempt to repair.
