Автор Тема: 12TV039R1  (Прочитано 284 раз)
12TV039R1
« : 04 Декабря 2023, 17:32:02 »
12TV039R1
Models
KDL-22/26EX555
KDL-32/40/46EX655
KDL-32HX755, 757, 758, 759
KDL-40HX755, 756, 757, 758, 759, 75G
KDL-46HX755, 756, 757, 758, 759, 75G
KDL-55HX755, 75G
KDL-40/46/55HX855
KDL-55/65HX955
Subject: Squeal noise from Tuner [REVISION 1]
Squeal noise (1kHz) may be audible.
CAUSE
Under no load condition (No LNB connected to the sat Tuner), the DiSEqC power IC falls into an intermittent
oscillation state causing mechanical vibration noise in three capacitors.
Change the three 10 μF film capacitors (C1005, C1006, C1008) indicated in the table below and refer to the picture
for the capacitor location.
Description Part number
Capacitor Ceramic 10MF 1-118-590-11
NOTE: After replacing the capacitors, put a check mark (“V”) next to the part number label on the main board, to
indicate a repair has been made. No other component repair is required/allowed. If above procedure fails, replace
the entire main board.
ASC REPORTING
Condition
code
Symptom
code
Part
number
Ref.
Section
code
PWB
Defect
code
Repair
code
Qty.
K 14A 1-118-590-11 12TV039 DPR BAPS N A 3
2 / 2 12TV039 R1
Modified boards (except for KDL-22/26EX555 and KDL-32EX655) are available as summarized in table below.
Model
Old board
M Label
New board KDL-22EX555 A1873434A BACS(S2) Replace the capacitors KDL-26EX555 A1874797A BACS(S2) KDL-32EX655 A1875711A BACS(S2) KDL-55HX955 FX00A4001 BAPS FX02A4001 KDL-65HX955 FX00A4001 BAPS KDL-32HX755 FX00A0401 BAPS(S2) FX02A0401 KDL-32HX757 FX00A0401 BAPS(S2) KDL-32HX758 FX00A0401 BAPS(S2) KDL-32HX759 FX00A0401 BAPS(S2) KDL-40HX755 FX00A0401 BAPS(S2) KDL-40HX756 FX00A0401 BAPS(S2) KDL-40HX757 FX00A0401 BAPS(S2) KDL-40HX758 FX00A0401 BAPS(S2) KDL-40HX759 FX00A0401 BAPS(S2) KDL-40HX75G FX00A0401 BAPS(S2) KDL-46HX755 FX00A0401 BAPS(S2) KDL-46HX756 FX00A0401 BAPS(S2) KDL-46HX757 FX00A0401 BAPS(S2) KDL-46HX758 FX00A0401 BAPS(S2) KDL-46HX759 FX00A0401 BAPS(S2) KDL-46HX75G FX00A0401 BAPS(S2) KDL-55HX755 FX00A0401 BAPS(S2) KDL-55HX75G FX00A0401 BAPS(S2) KDL-32HX755 FX00A0601 BAPS(MHP) FX02A0601 KDL-40HX755 FX00A0601 BAPS(MHP) KDL-46HX755 FX00A0601 BAPS(MHP) KDL-55HX755 FX00A0601 BAPS(MHP) KDL-40EX655 FX00A1601 BAPS(S2) FX02A1601 KDL-46EX655 FX00A1601 BAPS(S2) KDL-40HX855 FX00A1701 BAPS(S2) FX02A1701 KDL-46HX855 FX00A1701 BAPS(S2) KDL-55HX855 FX00A1701 BAPS(S2) KDL-40HX855 FX00A2201 BAPS(MHP) FX02A2201 KDL-46HX855 FX00A2201 BAPS(MHP) KDL-55HX855 FX00A2201 BAPS(MHP)
IMPORTANT: In case of board replacement, register the broken part in “Modreg” with the part number from modified “BAPS Compl (Service)” board (e.g. FX02xxxxx).
