Автор Тема: 12TV034  (Прочитано 211 раз)
12TV034
« : 04 Декабря 2023, 17:24:14 »
12TV034
KDL-40EX600, 603, 605
Subject: Panel / PSU Compatibility
When replacing the panel or Power Supply (Static Converter) board, make sure only to use compatible parts.
CAUSE
Panels each use different voltage ranges.
Refer to the table below to identify the Static Converter board to be used.
Panel Label info Part number PSU Label info Part number
SLCD LTY400HM02-XXX 1-811-137-11 GE3A 1-474-218-11
SLCD LTY400HM04-XXX 1-811-312-11 GE3E 1-474-273-11
