Автор Тема: 12TV023R0  (Прочитано 192 раз)
12TV023R0
« : 04 Декабря 2023, 12:29:20 »
12TV023R0
REACTIVE 3181 2 SBR
Models
AZ3_3A, AZ3_P2A Chassis
Subject: Broken Component input terminal
The screw holes of the component input terminals may be broken. As a temporary countermeasure himeron tape
has been used instead of screws.
For units with himeron tape added, the solution depends on whether or not the B board needs replacement.
 1. The “B board” needs NO replacement
=> No further action required. Do NOT screw this portion when attaching the rear cover.
 2. The “B board” needs replacement
=> You can choose between below options. Please refer to the picture on the next page for more details.
A. Adhering with the supplied screw.
Description Part number
Screw FX0012779
B. Sticking himeron tape.
Himeron tape FX0074401
NOTE: If going for option B, make sure NOT to additionally screw the component input terminals.
