Автор Тема: 12TV020R0  (Прочитано 201 раз)
12TV020R0
« : 04 Декабря 2023, 12:27:30 »
12TV020R0
REACTIVE 111F 2 SBR
Models
AZ3F_3A, 3AG Chassis
KDL-40EX650, 653, 655
KDL-46EX650, 653, 655
Subject: Reboot / No function
One of the following issues may occur, disabling all TV functions.
* Reboot after app. 100 minutes
* Abnormal picture after a couple of minutes
CAUSE
Crystal oscillator X9001 on the BAx board does not work correctly under high temperature.
Replace the BAx board if the symptom occurs and the two below conditions are simultaneously fulfilled.
1) The lot number must be “Mr59”, as in the second line in below example.
2) The set serial number must be in the list on the next page.
