Автор Тема: 12TV010R0  (Прочитано 233 раз)
12TV010R0
« : 04 Декабря 2023, 11:18:50 »
12TV010R0
REACTIVE K510 2 TD
Models
AZ-2F_2B-1, 2B-2, 2B-3, 3A-1, 3A-2, P-2
AZ-2W_P-1
Subject: No sound through ARC after deep Standby
When the Yamaha amplifier YHT-S351 or YHT-S401 is connected to the TV via HDMI ARC, sound may be absent
after the set has been in deep Standby.
CAUSE
Command timing issue.
Make sure to use the optical cable that is bundled with the Yamaha amplifier.
NOTE: In case of further problems, please directly contact the Yamaha service division mentioned on the warranty
card.
