Автор Тема: 12TV019R2  (Прочитано 377 раз)
12TV019R2
« : 04 Декабря 2023, 10:13:22 »
12TV019R2
PROACTIVE / REACTIVE 2 BC, TV
Models
AZ-3WK Chassis
Subject: Software Packages Follow-Up for AZ-3WK Chassis [REVISION 2]
The latest SW package (#4.03) has been released.
Issue
IRIS
code
Section
code
Rev.
Wrong display of characters when using CAM software of cable company UPC with
country settings “Hungarian”, “Austrian” and “Romanian”
K731 TUN R0
TV reboots when CAM is updated by OAD/OTA K11D FMW R1
A full empty banner instead of basic banner is displayed after a zapping. (Spain) 6738 IDS R2
Update to the latest SW version following the abridged procedure below.
1. Download and unzip the attached software package. Copy the included “*_.pkg” file to an empty USB stick.
Date SW Package
February 2013 AZ3WK_mt5367_pkg_4_03_eu.zip
2. Turn on the TV.
3. Insert the USB stick into the USB slot of the TV.
4. Press the [HOME] button to enter the set-up menu and select [Settings] => [Set-up] => [USB System Update].
5. When being asked “Do you want to start system update now?”, press [OK].
6. For a brief moment the message “Scanning” appears.
7. A warning message appears. Confirm by pressing [OK].
8. The update will start and take about 2 minutes, indicated by a progress bar. One LED will light up red, the other
one will flash in orange.
9. As soon as the update is finished, a message appears.
10. The red LED will change to green and the TV turns on automatically.
11. Remove the USB stick.
12. Confirm whether the software is correctly updated via the Settings menu, by pressing [HOME] => [Settings] =>
[Set-up] => [Product Support].
ASC REPORTING
Repair type
Condition
code
Symptom
code
Part
number
Ref.
Section
code
PCB
Defect
code
Repair
code
Qty.
Proactive (NPF) 12TV019 SFT 6 2
Reactive (issue not listed) 12TV019 1 2
Reactive (issue listed) issue issue 12TV019 issue 1 3
2 / 2 12TV019 R2
REVISION HISTORY
Rev.
R0
R1
R2
SW
#4.01
#4.02
#4.03
Date
22.06.12
13.08.12
27.02.13
12TV019 - Software Packages Follow-Up for AZ-3WK Chassis [REVISION 2]
