Автор Тема: 12TV003R6  (Прочитано 332 раз)
12TV003R6
« : 04 Декабря 2023, 10:06:20 »
12TV003R6
PROACTIVE / REACTIVE 2 BC
Models
AZ-2EK_P-1F Chassis
Subject: Software Packages Follow-Up for AZ-2EK_P-1F Chassis [REVISION 6]
The latest SW package (#4.09) has been released for software fixes.
Issue IRIS
code
Section
code
Rev.
Random audio dropout for a second when connecting an external device by HDMI K553 APD
R0
Freeze after zapping to France24-English (Turkey) 611F DPR
Wrong Cyrillic subtitles (font coding CP1251) when reproducing files from USB
(Bulgaria / Russia / Ukraine) K37E SFT R1
Wrong display of characters when using CAM software of cable company UPC with
country settings “Hungarian”, “Austrian” and “Romanian” K731 TUN R2~3
TV reboots when CAM is updated by OAD/OTA K11D FMW R4
A full empty banner instead of basic banner is displayed after zapping (Spain) 6738 IDS R5
Update to the latest SW version following the abridged procedure below.
1. Software fixes
1-1. Download and unzip the attached software package. Copy the included “*_.pkg” file to an empty USB stick.
Date SW Package
March 2013 AZ2EK_mt5366_pkg_4_09_eu.zip
1-2. Turn on the TV.
1-3. Connect the USB stick. A message “There are no items to display” will appear.
1-4. Press the [HOME] button to enter the set-up menu and select [Settings] => [Set-up] => [USB System Update].
1-5. When being asked “Do you want to start system update now?”, press [OK].
1-6. For a brief moment the message “Scanning” appears.
1-7. A warning message appears. Confirm by pressing [OK].
1-8. The update will start and take +/- 2 minutes, indicated by an on-screen progress bar and 2 green LEDs
flashing.
1-9. As soon as the update is finished, a message appears.
1-10. One green LED lights up again and the TV turns on automatically.
1-11. Remove the USB stick.
ASC REPORTING
Repair type Condition
code
Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
Proactive (NPF) 12TV003 SFT 6 2
Reactive (issue not listed) 12TV003 1 2
Reactive (issue listed) issue issue 12TV003 issue 1 3
2 / 2 12TV003 R6
1-12. Confirm whether the software is correctly updated via the Settings menu, by pressing [HOME] => [Settings]
=> [Set-up] => [Product Support].
2. Panel / Main board update
In case the panel or Main board needs replacing, confirm whether the panel settings are as indicated below.
Model Panel name in Service menu
KDL-22EX310 22W_LG22
KDL-32EX310 23W_LG32
KDL-42EX310 24W_LG42
The panel settings can be changed via the Service menu.
2-1. Enter the Service menu by consecutively pressing “[i+]”, “[5]”, “[Vol+]”, “[Power]”.
2-2. Go to the “Panel selection”.
2-3. Change the panel settings to the one indicated in above table.
2-4. Power off to store the data.
12TV003 - Software Packages Follow-Up for AZ-2EK_P-1F Chassis [REVISION 6]
