Автор Тема: 11TV048R1  (Прочитано 201 раз)
11TV048R1
« : 04 Декабря 2023, 10:03:40 »
11TV048R1
REACTIVE 138A 2 SBR
Models
KDL-40NX720, 723, 725
KDL-46HX820, 823, 825
KDL-46NX720, 723, 725
KDL-55HX820, 823, 825
KDL-55NX720, 723, 725
Subject: Light Leakage [REVISION 1]
Light leakage may occur between the glass and the cabinet.
CAUSE
The glass may partially peel off due to specific environmental conditions.
 Add pieces of blind tape to the panel / glass top.
Description Part number
Tape, Acetate (No.5) 7-600-029-52
 The amount of side tape that needs to be added depends on the panel type used. To locate the panel serial
number, refer to the back of the panel (upper right corner).
Inch
size
Serial number label
SCID Panel (LONG side pieces) 3M Panel (SHORT side pieces)
40 A1808272B ~0104702 A1808272B 0104703~
46
A1809249C ~0137499 A1809249C 0137500~
A1808284A ~0069087 A1808284A 0069088~
55
A1808276A ~0058010 A1808276A 0058011~
A1808288B ~5051573 A1808288B 5051574~
