Автор Тема: 11TV047R1  (Прочитано 206 раз)
11TV047R1
« : 04 Декабря 2023, 10:02:27 »
11TV047R1
REACTIVE 2 TD
Models
AZ-2F_3A-1, 3A-2 Chassis
Subject: 3D Picture Cross Talk [REVISION 1]
Cross talk (same picture displayed two times) may occur while watching 3D (Simulated) picture on 100 Hz models.
CAUSE
Panel specifications.
In the Settings menu, disable the “Motion Flow” option.
IMPORTANT
 The Motion Flow setting can only be changed when the input signal is 24 or 50 Hz in 3D (Simulated) mode,
not if it is 60 Hz.
 The problem cannot be fixed by exchanging any part.
