Автор Тема: 11TV039R1  (Прочитано 199 раз)
11TV039R1
« : 04 Декабря 2023, 09:53:45 »
11TV039R1
REACTIVE 2 TD
Models
KDL-65HX920, 923, 925
Subject: Rear Cover Disassembly
The rear cover may be difficult to remove.
CAUSE
Tight fitting for esthetic purposes.
Whenever removing the rear cover, follow the guidelines below, making sure not to damage the bezel.
1. Fold “Himeron tape” over the blade of a slotted (—) screwdriver to avoid scratches.
NOTE: You may use substitute tape, but in any case avoid thick tape.
2. At bottom side, position the screwdriver into the clearance between bezel and rear cover and use it as a lever to
