Автор Тема: 11TV032R2  (Прочитано 214 раз)
11TV032R2
« : 03 Декабря 2023, 03:21:08 »
11TV032R2
REACTIVE 1651 2 TD
Models
AZ-2F_2B1, 2B-2, 2B-3, 3A-1, 3A-2, P-2 Chassis
AZ-2W_P-1 Chassis
Subject: Unstable or Tilting TV [REVISION 2]
The TV set may tilt or be unstable on the TV stand.
CAUSE
Misalignment between stand neck and stand base. Screws cannot be fully tightened or are stuck due to being
covered by lock tight during production.
1. Confirm the lock tight colour of the malfunctioning screw(s). When it is white or yellow, replace with the new
screws indicated below, being blue or violet and offering a tightening performance improvement of 30~40 percent.
OLD NEW
Description Description Part number
Entrust, Old Screw Lock: EG Grip WHITE Entrust, New Screw Lock: NDS finish (30 mPs) VIOLET 4-259-541-02
Iwata Bolt, Old Screw Lock: KR255 YELLOW Iwata Bolt, New Screw Lock: SSG(30mPs) BLUE
