Автор Тема: 11TV030R3  (Прочитано 252 раз)
11TV030R3
« : 03 Декабря 2023, 03:19:43 »
11TV030R3
PROACTIVE / REACTIVE 2 TD
Models
AZ-2EK_P-2F, 2V Chassis
Subject: Software Upgrading Procedure for AZ-2EK Chassis [REVISION 3]
This Technical Bulletin describes the upgrading procedure for the AZ-2EK chassis using a USB stick. An update is
needed in case of software fixes and Main board or Panel exchange.
Model Main board part number
KDL-22CX32D WS0024901
KDL-xxBX32x WS0016301
KDL-32BX320 1-857-896-71
KDL-xxBX42x WS0016401
KDL-40BX420 1-857-896-81
1. SOFTWARE UPDATE
Preparation
* Download and unzip the “AZ2EK_pkg_*_eu.zip” software package file attached to TB 11TV031.
* Copy it to an empty USB stick.
Update procedure
1-1. Turn on the TV.
1-2. Connect the USB stick. A message “There are no items to display” will appear.
1-3. Press the [HOME] button to enter the set-up menu and select [Settings] => [Set-up] => [USB System Update].
1-4. When being asked “Do you want to start system update now?”, press [OK].
1-5. For a brief moment the message “Scanning” appears.
1-6. The attention message below appears. Confirm by pressing [OK].
