Автор Тема: 11TV026R2  (Прочитано 209 раз)
11TV026R2
« : 03 Декабря 2023, 03:16:57 »
11TV026R2
REACTIVE 2 TD
Models
KDL-40CX520, 521, 523, 525
Subject: SLCD and CMI Panel Compatibility [REVISION 2]
Two types of LVDS Harness (FFC) exist to connect the panel to the B board. Both parts are compatible on
condition of using the correct FFC.
1. Choose the correct FFC depending on the panel maker.
Panel Flexible Flat Cable
Label info Part number Part number
SLCD 40ESP (LTU400HM02-XXX) 1-811-329-11 FX0026711
CMI (V400H1-L11) 1-811-401-11 FX0040111
2. Additionally add the tape indicated below.
Description Part number
Tape (3M 1350FW-1) 15MMX66M WHT FX0003697
Tape (3M 1350FB-1) 15MMX66M BLK
FFC Localization
