Автор Тема: 11TV021R1  (Прочитано 185 раз)
11TV021R1
« : 03 Декабря 2023, 03:09:14 »
11TV021R1
AZ-1H_1A, 2A-1.5 Chassis
AZ-1L_2B-1, 2B-1.5 Chassis
Subject: 3D Cross Talk Check (200 Hz) [REVISION 1]
3D cross talk may occur.
Confirm whether cross talk occurs by establishing the conditions below.
* Input signal: Test pattern (HDMI, 1920*1080 60p)
Preparation
- Copy the attached “3D_Crosstalk_200Hz.bmp” or “3D_Crosstalk_200Hz.jpg” file to a USB device.
- Insert this USB device into a PS3 or BD Player and connect to TV via HDMI.
- Select the USB device and play the file.
* Measurement condition (3D Mode).
1. Via the Options menu, select the below settings.
- “3D Display” => “ON”
- “3D Format” => “Over-Under” (Top and Bottom)
2. Confirm the TV display.
3. Via the Options menu, select the below setting.
- “3D Format” => “3D glasses brightness” => “Low”
- Picture mode: Standard.
- Eco (System Settings => Eco): All items – Off.
* Ageing condition.
- Status: HDMI-input (w/ signal).
- Setting: Same as measurement condition
- Temperature Setting: Normal temperature (25 °C)
- Period: Recommended time is 120 min. (Less time is OK, provided it meets the specification.)
