Автор Тема: 11TV008R0  (Прочитано 231 раз)
11TV008R0
« : 02 Декабря 2023, 20:49:47 »
11TV008R0
CAUTION NOTE X185 2 BC
Models
KDL-55EX720, 721, 723, 725
Subject: Rear Cover Disassembly
To minimize the gap around the side-jack area, double adhesive tape was applied during production. The adhesion
of the tape may diminish over time.
When disassembling, check the condition of the adhesive tape.
When re-using the rear cover afterwards, it is recommended to replace the tape.
1. How to release the rear cover?
1-1. Remove all screws.
1-2. Lift up the rear cover bottom about 30 mm.
1-3. Insert your fingers between the rear cover and panel at side jack side, and gradually peel off the panel, being
careful not to bend the rear cover.
