Автор Тема: 11TV005R0  (Прочитано 231 раз)
11TV005R0
« : 02 Декабря 2023, 19:12:51 »
11TV005R0
CAUTION NOTE 2 BC
Models
KDL-32EX421, 424, 425, 520, 521, 523, 524, 525, 720, 721, 723, 724, 725, 726, 727, 728, 729
Subject: Rear Cover Disassembly
When opening the rear cover for disassembly, the fitting hook points can be damaged.
CAUSE
Tight fitting hook from bezel to rear cover.
To avoid any damage, remove the fitting hooks in the order of the figure below (1 => 6).
NOTES
* Please make sure your working surface is clean.
* In the procedure on the next page (example for hook position 1) the 40 mm wide piece of tape is only attached
for reference reasons. It is not needed for normal repair.
