Автор Тема: 11TV001R1  (Прочитано 201 раз)
11TV001R1
« : 02 Декабря 2023, 19:09:00 »
11TV001R1
PROACTIVE / REACTIVE 2 BC
Models
AZ-1BD Chassis
Subject: Software Upgrade Procedure for BDP Unit AZ-1BD Chassis [REVISION 1]
This Technical Bulletin describes the software upgrade procedure for the integrated BDP-S370/373 unit in all
AZ-1BD Chassis models.
Depending on your setup, choose between the options below.
 TV connected to Internet => NETWORK upgrade (= Recommended)
 TV not connected to Internet => DISC upgrade
Version number confirmation
If the last three digits of the version number are lower than those of the file name attached to TB 11TV002, an
upgrade is needed (e.g. File ‘M03R695.zip’ = Version 695).
* Power on the TV and press the [HOME] button on the remote commander to display the Home Menu (XMB).
* Navigate to 'Blu-ray Disc Player' under ‘Settings’ and press [OK] to select it.
* Navigate to ‘System Settings' and select it.
* Navigate to ‘System Information’ and select it. The firmware version currently installed will be shown.
