Автор Тема: 10TV070  (Прочитано 203 раз)
10TV070
« : 02 Декабря 2023, 18:33:26 »
10TV070
KDL-32EX600, KDL-32EX603, KDL-32EX605 BC
Subject IRIS
Caution when replacing Panel
Panels of different manufacturers have been used during production.
Whenever replacing, make sure to use a panel of the same manufacturer.
1. Identify the panel type, using the panel label.
Model Chassis OLD S-LCD Panel NEW CMO Panel
Serial number Part number Serial number Part number
KDL-32EX600 AZ-1N
9300001~9390001 1-811-136-xx 9600001~9690001 1-811-276-xx
8000001~8090001 1-811-136-xx 8500001~8590001 1-811-276-xx
KDL-32EX603 AZ-1L 9000001~9090001 1-811-136-xx 9200001~9290001 1-811-276-xx
KDL-32EX605 AZ-1L 9300001~9390001 1-811-136-xx 9600001~9690001 1-811-276-xx
2. Guide the FFC 51P Cable, making sure only to use compatible parts. Refer to the pictures on the next page for a
visualisation.
Description 32 S-LCD 32 CMO
Panel 1-811-136-xx 1-811-276-xx
FFC cable 1-838-126-11 1-838-580-11
Static converter 1-474-218-11 (GE3-B) 1-474-249-12 (GE3-D)
Conductive Tape 4-117-707-01 /
Sheet Core A 4-118-465-01 /
Sheet Core C
3x Sheet Core C
(4-000-896-01)
(SB405)
4x Sheet Core C
(4-000-896-01)
(SB405)
3. Update the software to the latest version, using the file attached to Technical Bulletin 10TV005 (AZ-1N Chassis)
or 10TV021 (AZ-1L Chassis).
