Автор Тема: 10TV065  (Прочитано 208 раз)
10TV065
« : 02 Декабря 2023, 18:12:07 »
10TV065
AZ-1H_2A-1.5 Chassis, AZ-1H_2A-2.5 Chassis BC
Subject IRIS
CAM Slot missing 161X
The CAM slot is missing from KDL-40NX710 if within the serial number range below.
NOTE: Other AZ-1H_2A-1.5/2.5 models may have been produced without CAM slot. Therefore, always make sure
to check in case of a repair.
CAUSE
Use of incorrect (analogue) Side Jack Bracket.
If the symptom occurs, replace the Side Jack Bracket to the part indicated below.
Description Part number
Side Jack Bracket 4-188-665-21
APPLICABLE SERIAL NUMBERS
Model Serial number
KDL-40NX710 9300628~9301190
