Автор Тема: 11TV020R1  (Прочитано 198 раз)
11TV020R1
« : 02 Декабря 2023, 17:45:19 »
11TV020R1
REACTIVE D346 2 TD
Models
AZ-1H_2A-2.5, AZ-1L_3A-0.3 Chassis
Subject: 3D Cross Talk Check (100 Hz) [REVISION 1]
3D cross talk may occur.
Confirm whether cross talk occurs by establishing the conditions below.
* Input signal: Test pattern (HDMI, 1920*1080 60p)
Preparation
- Copy the attached “3D_Crosstalk_100Hz.bmp” or “3D_Crosstalk_100Hz.jpg” file to a USB device.
- Insert this USB device into a PS3 or BD Player and connect to TV via HDMI.
- Select the USB device and play the file.
* Measurement condition (3D Mode).
1. Via the Options menu, select the below settings.
- “3D Display” => “ON”
- “3D Format” => “Over-Under” (Top and Bottom)
2. Confirm the TV display. 
3. Via the Options menu, select the below setting.
- “3D Format” => “3D glasses brightness” => “Low”
- Picture mode: Standard.
- Eco (System Settings => Eco): All items – Off.
* Ageing condition.
- Status: HDMI-input (w/ signal).
- Setting: Same as measurement condition
- Temperature Setting: Normal temperature (25 °C)
- Period: Recommended time is 120 min. (Less time is OK, provided it meets the specification.)
* Power supply input: Normal state.
* Others: Factory settings.
