Автор Тема: 11TV002R1  (Прочитано 351 раз)
11TV002R1
« : 02 Декабря 2023, 17:11:54 »
11TV002R1
PROACTIVE / REACTIVE 2 BC
Models
AZ-1BD Chassis
Subject: Software Packages Follow-Up BDP Unit AZ-1BD Chassis [REVISION 1]
The latest software package #769 has been released for updating the BD Player software included in all models of
the AZ-1BD chassis, remedying the below issues.
Issue IRIS
code
Section
code Rev.
BD Disc warning message (No playback)
* A message may appear urging to update the software of
the player. Auto playback does not start.
NOTE: If the [Enter] button is pressed, the playback does
start after all.
S18C R0 R0
Spec upgrade: Correspondence for AVCHD 1080/60p,
1080/50p playback / F716 R1 R1
Update the BD Player with the latest software (M03R769), using the file attached to this document and referring to
Technical Bulletin 11TV001 for the upgrade procedure (Option 2: “DISC Upgrade”).
Date Attachment Files
October 2011 az1_bdp_firmware_M03R769.zip
BD8530FE.bin
build_fw_msb03.bin
11TV002 - Software Packages Follow-Up BDP Unit AZ-1BD Chassis [REVISION 1]
