Автор Тема: 10TV059  (Прочитано 219 раз)
10TV059
« : 02 Декабря 2023, 16:27:28 »
10TV059
AZ-1H_1A, AZ-1H_2A-2 Chassis BC
Subject IRIS
Rear Bottom Cover Detachment 162X
The cover for cable connections at the bottom rear side of the set may detach spontaneously.
CAUSE
Plastic boss that is inserted to the rubber catch when attaching the cover being too thin and the resistance level too
low. Due to looseness of the attaching form, the cover may detach.
Please apply 2 cushions to cover the bottom, as shown in the pictures.
Description Part number Remark
Cover Bottom 40-46 inch 4-165-763-01 Cover bottoms with suffix -02
have the countermeasure
already applied
Cover Bottom 52 inch 4-165-764-01
Cover Bottom 60 inch 4-165-765-01
Filter Cushion 4-262-871-01
