Автор Тема: 10TV058R2  (Прочитано 220 раз)
10TV058R2
« : 02 Декабря 2023, 16:26:24 »
10TV058R2
REACTIVE 137C 2 BC
Models
AZ-1H_1A, 2A-1.5, 2A-2.5 Chassis
AZ-1L_2B-1, 2B-1.5 Chassis
AZ-2F_2B-1, 2B-2, 2B-3, 3A-1, 3A-2 Chassis
TDG-BR50, 100, 200, 250
Subject: Filter for 3D Glasses [REVISION 2]
When watching 3D content the image may be disturbed.
CAUSE
3D glasses for the listed models do not have a polarizer in the front (image side) to avoid flickering of environment
light. As side effects by this, when a face is leaned aslant, picture crosstalk arises because the polarization axis of
the lens inclines.
 Add a filter to the front of 3D glasses lenses (image side), following the instructions outlined below.
IMPORTANT
In case the customer experiences flickering of environment light using 3D glasses with this filter, it is
highly recommended to stop using this filter immediately.
These filters are prepared only for customers who strongly complain about “double image”. It is necessary to warn
them that applying a filter may worsen the flickering side effect.
 Depending on the size of the glasses, a different filter has to be used.
