Автор Тема: 10TV057R1  (Прочитано 216 раз)
10TV057R1
« : 02 Декабря 2023, 16:24:42 »
10TV057R1
AZ-1K_5-3, AZ-1K_5-3D Chassis BC
Subject IRIS
Sound Level Adjustment Problem [REVISION 1] 172X
Sound level can be adjusted only to “0”, “25”, “50”, “75” or “100”. After Power On, sound level is always at level
“50”.
CAUSE
Set is in Factory mode.
Proceed as indicated below.
1. In the User Menu, go to the Settings Menu and press “2023”.
2. Select “Option 0”.
3. Set “Standby” to “Customer”.
