Автор Тема: 10TV046R2  (Прочитано 198 раз)
10TV046R2
« : 02 Декабря 2023, 16:05:45 »
10TV046R2
REACTIVE 2 BC
Models
AZ-1BK_5-3, AZ-1BK_5-3D Chassis
Subject: Software Upgrade Procedure for AZ-1BK Chassis [REVISION 2]
This Technical Bulletin describes the upgrade procedure for the AZ-1K chassis, using a USB stick. All software files
are attached to Technical Bulletin 10TV047.
An upgrade is needed in one of the following cases:
 1. Issue fixes.
 2. Main Board exchange.
 3. Panel exchange.
 4. DVD module replacement.
1. Issue fixes
1-1. Extract the appropriate Application SW file (“USER_UPDATE_*.zip”), attached to TB 10TV047, and copy the
included “AP.bin” file to the root folder of your USB Stick.
Model File Main board P/N
KDL-19BX200
USER_UP_NORMAL*.zip
1-857-682-11
KDL-22BX200 1-857-683-11
KDL-22BX20D USER_UP_COMBO*.zip 1-857-684-11
1-2. Plug in the USB Stick.
1-3. Connect the AC Cord.
1-4. The update will automatically start. Wait until the message “Please remove the USB device and wait for
rebooting” appears.
1-5. Remove the USB Stick from the memory slot. The TV will reboot by itself.
1-6. Verify the upgrade version in the User Menu (=> 5. Upgrade verification).
